What should the timing be set at for a stock 502 magnum carb version
thank you again
34* @ 3000rpm's and initial timing will fall where it may . :cool-smiley-011:
OEM Mercruiser spec here is 8 degrees BTDC. That's for Gen IV, V, VI, Carb models
thanks
mine is a gen 5 carb with msd ignition, coil and distributor, does the timing stay the same regardless of using thunderbolt or msd?
Originally Posted by BUP
(Post 4143085)
My post was incomplete and you thru out a curve ball as your post said "stock 502 Mag carb version"
OEM Stock Mercruiser ignition set up on a stock Mercruiser 502 mag carb is 8 degrees BTDC at idle speed 650 rpms. I take it you have Mercruiser and do you have any of the Mercruiser T - bolt ignition set up or is this all MSD ? IMO 8 to 10 would seem right at idle speed of 650 rpm. |
Sorry I later read some other posts and realized that mine isnt actually "stock stock"
All msd coil, distributor, ignition |
Originally Posted by stimleck
(Post 4143140)
thank you
do you agree with this method of adjusting carb mixture for a boat? https://www.youtube.com/watch?v=UPGLUsW5ZeE
Originally Posted by mike tkach
(Post 4143188)
as already posted,set total at 34 and dont worry about initial.
(Post 4143214)
thank you
do you agree with this method of adjusting carb mixture for a boat? https://www.youtube.com/watch?v=UPGLUsW5ZeE |
thanks
(Post 4143755)
yes,after engine has warmed up put it in gear,then make your adjustments.a member tried to set the mixture screws at 1/2 turn out and said that is the way to do it but it is not.the idle mixture will be to lean and might cause a backfire or lean pop.
| All times are GMT -5. The time now is 08:59 PM. |
