It looks like it can be done, however tough to replace the small seal and then line up the wear plate and bolt holes and impeller.
Easier to pull the pump. You will want to change the fuel pump lube too because gas always gets in there.
Originally Posted by HyFive578
(Post 4147056)
Thanks pwraddr. That is helpful.. I would still like to know if it can be done without removing the pump from the engine ?? ie: just unbolt the plastic housing, replace the impeller and rebolt the plastic housing.
Originally Posted by Sydwayz
(Post 4147101)
It can be done, and I imagine on your center and/or engine(s), you do not have much clearance to pull things off the motor forward. You really do want to remove the whole pump. You would be forced to bend two very stiff hoses (intake & discharge) to remove them from the back of the pump housing, and they are on plastic barbs. You will likely crack one or both of the plastic barbs while trying to attempt this. It's in your best interest to pull the whole pump/pulley assembly forward to remove it.
(Post 4147383)
Got to it, this afternoon. Removing the hoses was a piece of cake. I wound up leaving the pump on the engine but I did loosen the tension on the serpentine belt and that gave me enough wiggle room to disassemble and reassemble everything without a problem. Tested out on the water today and all good.. Very easy to do..
Originally Posted by thirdchildhood
(Post 4147390)
The lube reservoir is most likely full of gasoline. Changing the oil is part of the job.
Also, if you take all 5 bolts out to change the impeller, the pump is off the bracket / motor. Unsure then how it was done with removing. |
Originally Posted by Pwraddr
(Post 4147481)
Very true, both mine were full.
I think I'm going to do the other pumps now.. But this time, I will heed your advice and remove the pumps entirely so I can change the lube. What do you guys use to plug the fuel lines?
(Post 4148156)
guys I have easy access to the back of my pump to change the impeller, is there any reason I should still remove the entire pump to do it?
(Post 4148156)
| All times are GMT -5. The time now is 09:14 AM. |
