-   -   higer oil temp after rebuild, bypass?? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/314494-higer-oil-temp-after-rebuild-bypass.html)
SB 07-01-2014 08:28 PM
Originally Posted by donzi matt (Post 4146781)
This is how most of my experiments in the name of science work out.
As you must know already, if you don't bleed, you didn't do it correctly.
Also, be more nervous about no bolts/nuts left over than having some left over.
dereknkathy 07-01-2014 09:12 PM
is it possible that newer tighter motor, less oil spraying around and more staying in the bearings longer gives oil more time to heat up?
onesickpantera 07-01-2014 09:20 PM
I agree shoot the filters with a temp gun first. Also, while unlikely, is it possible that one engine is reading the temps after the cooler and one before? Maybe hose routing after the rebuild?
MILD THUNDER 07-01-2014 09:31 PM
Oil stat element fully opened just before the water boiled.
donzi matt 07-01-2014 09:32 PM
How is the boo-boo?
BUP 07-01-2014 09:38 PM
I would shoot a temp gun at the oil pan, oil filter and the sender compare that then compare against the other engine doing the same.. This would be the easiest and first place to start as others mentioned.
MILD THUNDER 07-01-2014 09:40 PM
Originally Posted by donzi matt (Post 4146842)
How is the boo-boo?
lol, its not bad . At first I thought stitches, but then realized I was being a puzzy. Its a minor slice. :helmet:
donzi matt 07-01-2014 09:41 PM
Put some RTV in it than wrap it with duct tape.
Done
MILD THUNDER 07-01-2014 09:50 PM
direct from the 500EFI merc manual
Oil temp at 5200RPM=170-180*. (Full throttle)
I dont know how mercury racing got away with those temperatures. On oso, you need 250* oil temps or your engine will get milkshaked, not lubricate properly, and destroy itself. You need to get high oil temps to burn off the water coming in from your poor choice of camshaft selection thats reverting.
Page 76.
http://www.mercuryracing.com/_media/...5010%20500.pdf
MILD THUNDER 07-01-2014 09:52 PM
Done
Which brand RTV would you suggest? Is ultra black ok? Or ultra grey? Or Ultra blue? Or hylomar? How much should i use? Where is budman anyway?
