TRS issues
Does anyone have a schematic for a TRS lower. I was at the lake and got into mud. After I made it to the main lake I had a small vibration in the starboard motor. After getting her home and inspecting I have found that when turning the prop by hand 30 to 45 degrees out of 360 I can feel it hanging up almost similar to missing a gear tooth or two.
Lower pinion gear went, that is the smallest gear in the TRS, soon as they start to pit they go shortly after, most likely dint have anything to do with the mud, more just a TRS thing, or any drive really....
You're pretty close. The pinion gear was worn however I sheared three teeth off of the drive gear. The price isn't great but the parts are available and now I won't have to worry about that drive for quite a while.
yea, one normally wipes put the other....
| All times are GMT -5. The time now is 10:29 PM. |
