-   -   Stainless sea pump opinions (https://www.offshoreonly.com/forums/do-yourself-boating-budget/315236-stainless-sea-pump-opinions.html)
ckcgobigblue 07-14-2014 11:20 PM
Well I've had a lot of problems out of my raw water pump and impeller. I replaced plastic housing and impeller still leaked checked it again now I see that water is leaking out the weep hole on the metal housing. So now I'm just going to buy a whole new pump and housing, I'm fed up and afraid of just redoing the seals. So my question is the brass vs stainless steel ones opinions and reviews, they are pretty much the same price. The stainless takes screw in hoses which I don't have so I would have to buy some adaptors but I think I'm leaning towards stainless just because I figured it would be more durable. Any info is appreciated. My engine is a 454 without the fuel pump connected
ThisIsLivin 07-15-2014 08:01 AM
The stainless is the way to go, I've had mine for several seasons and it still looks new inside. Be prepared to do some work and clean up the sharp edges internally.
ckcgobigblue 07-15-2014 09:16 PM
What did you clean up the edges with?
brian41 07-16-2014 06:15 AM
Hardin stainless pumps on everything we build.
ThisIsLivin 07-19-2014 06:44 PM
Sandpaper roll on a die grinder. I also smoothed out the pathways for the water flow. My impellers last longer now than with the plastic housings.
