Engine Mounts
I know the mounts for the motors themselves are usable on a big or a small block. How ever is the base assembly mount (the one bolted into the boat) for a small block able to be used with a big block?
Yes for all chevy engines
Same bolt pattern for the coupler housing, but Bravo coupler has a larger opening than one for an Alpha.
mounts in same place bbc and small block. moved back a bit for v6.
Originally Posted by dereknkathy
(Post 4158170)
This one I am sure of. I have switched out a small block for a big block on two boats with my father (he was the knowledge and I was the free wrench). But since he passed away I am trying to do things with a combination of memory, and you guys.
Originally Posted by mike tkach
(Post 4158184)
are you sure about that,i think the small block mounts a little farther back than the big block.
| All times are GMT -5. The time now is 11:59 AM. |
