My 502 got Wet!!!
SubscribeWell this just sucks!
My lift busted while I was away for the weekend and the aft of my 1998 Baja 502 EFI went under (fresh water). I guess the good part is it wasn't running and it was fresh water.
Am I looking at a total rebuild? There is no water in the Oil at all.
I haven't touched it yet, so I dont know if it will start or turnover, I wanted to get some advice before I tried to fire it up.
Cheers!
Cheers!
Sydwayz
Forum Regulator
close
- Join DateMay 2001
- LocationWorldwide
Liked:1,612 Times in 719 Posts
How far under is the water line? My 468 got wet in my jet boat when I lost a main cooling line. Water was over the starter and the oil pan. Once dried out, I didn't even lose the starter.
WTF, lift failed, and boat leaked. You had a bad week!
Did any electronics get wet? If so you probably can't just start it.
But since the engine has no water in the crankcase you might have dodged that bullet. So remove the spark plugs and spin out any water in the combustion chambers right away. Doesn't have to turn backwards, the plugs are out. If you get water out of the spark plug holes, oil the combustion chambers and valves. Then if you can't start it you can at least preserve the engine til you can fix the electrics. That can be done by bypassing the ignition either with a remote starter button or by pulling your kill lanyard so you can crank it over without starting. The remote button is best because you won't energize the fuel injection system. After you have cranked out any water with the plugs removed, put some fog oil in the spark plug holes and thread in your old spark plugs. Crank the engine for a few seconds (10 or 15ish) while fogging through the throttle body. That's going to get the valves preserved.
Keep pulling the oilstick and checking, it might take some time for water to get there without running the engine.
Quote:
But since the engine has no water in the crankcase you might have dodged that bullet. So remove the spark plugs and spin out any water in the combustion chambers right away. Doesn't have to turn backwards, the plugs are out. If you get water out of the spark plug holes oil the combustion chambers and valves. Then if you can't start it you can at least preserve the engine til you can fix the electrics. That can be done by bypassing the ignition either with a remote starter button or by pulling your kill lanyard so you can crank it over without starting. The remote button is best because you won't energize the fuel injection system. After you have cranked out any water with the plugs removed, put some fog oil in the spark plug holes and thread in your old spark plugs. Crank the engine for a few seconds (10 or 15ish) while fogging through the throttle body. That's going to get the valves preserved.
Thanks Guys!Originally Posted by NHGuy
Did any electronics get wet? If so you probably can't just start it. But since the engine has no water in the crankcase you might have dodged that bullet. So remove the spark plugs and spin out any water in the combustion chambers right away. Doesn't have to turn backwards, the plugs are out. If you get water out of the spark plug holes oil the combustion chambers and valves. Then if you can't start it you can at least preserve the engine til you can fix the electrics. That can be done by bypassing the ignition either with a remote starter button or by pulling your kill lanyard so you can crank it over without starting. The remote button is best because you won't energize the fuel injection system. After you have cranked out any water with the plugs removed, put some fog oil in the spark plug holes and thread in your old spark plugs. Crank the engine for a few seconds (10 or 15ish) while fogging through the throttle body. That's going to get the valves preserved.
The water came just below the EFI unit - to the top of the intake.
I will try spinning the water out and see what happens.
thirdchildhood
close
- Join DateOct 2005
- LocationClarkston, Michigan
Liked:612 Times in 275 Posts
Fresh water? I think it will be fine once you dry everything out.
My old Maxum had some epoxy on a scratch from an incident with a stump. Well apparently that stuff came off on the way to the beach because we pulled it up on the sand a little and an hour or so later there was water 6" deep in he cockpit. Rut roh.
Hit the bilge and for a while and the old 305 fired right up. Never missed a lick after that either.
thirdchildhood
close
- Join DateOct 2005
Quote:
Yeah, why, and won't that screw up the raw water pump impeller?Originally Posted by cheech
Why backwards?
