Found a Carb rebuild Guy for $155 on eBay - FYI
Getting ready to try this guy - seems reasonable and has many carb rebuilds as samples - not to mention it's on Ebay so i'd be somewhat protected.
Thought i'd share the link if anyone needs a carb done and doesn't have a local shop/guy.. Dave http://www.ebay.com/itm/231385302097...%3AMEBIDX%3AIT |
Report back after its done and tested.
Allstate carbs is a nice guy to deal with and reasonable too.
Sounds like a deal for a $20 gasket set and some rattle can.
the add said the carb is media blasted and for no xtra cost he will remove the choke horn.looks like more than a gasket&rattle can job.
Originally Posted by mike tkach
(Post 4225247)
All I know is for a basic rebuild do not go with Nickerson.
Media blasting the Carb ??? you want not have porosity in a carb or cause it internally. Plus would nt be hard to clean up the carb with all the blasting material after the fact from cleaning it with the media.
I've had to do that back in the day had a hat and greased block with studs and wingnuts for holleys to seal em off similar deal for the quadrajets ,getting the finish back on that alloy was tricky .and expensive .if someone out there is rebuilding a boat Holley for less than $100 net it truly is the end .
| All times are GMT -5. The time now is 11:23 AM. |
