-   -   Velvet drive 72c v drive (https://www.offshoreonly.com/forums/do-yourself-boating-budget/320548-velvet-drive-72c-v-drive.html)
jamie 10017 11-26-2014 06:59 PM
Im in the process of rebuilding my transmissions and checking over the v drive units . I am installing graphite clutches in the trans but was wondering if any other mods I should do ? Its not a go fast boat 5000 rpm max BBC's rather mild maybe 475 hp it weighs 15000 lbs just want reliable units so any suggestions ? Thanks Jamie
jamie 10017 12-01-2014 04:02 PM
This seems like TOP SECERT info here if it were a automotive transmission everyone would chime in but a velvet drive is hush hush . What have you tried that worked or didn't work just looking for ideas etc. Thanks Guys Jamie :flag:
14 apache 12-01-2014 06:15 PM
:waffen093::violent040: Was it burned up or just a freshening? And not many people will tell much. As you can see.
jamie 10017 12-01-2014 08:52 PM
Just refreshing the units while I have the engines out. Added a few ponies but nothing wild , just torque motors.
ezstriper 12-02-2014 08:47 AM
they had some clutch pack setups that took more clutches than others, that along with good clutches are all I ever heard about...had mine done not long ago...
jamie 10017 12-02-2014 06:18 PM
Ezstriper who did your transmissions ? I am installing extra clutches in mine and I have heard of guys raising the pump pressure but I have never tried it myself .
Jamie
14 apache 12-02-2014 10:08 PM
Jamie
Dont raise it to much the more psi the less oil gose through the cooler.
ezstriper 12-03-2014 08:05 AM
I did not raise pressures, mine were done by the same guy who builds my race trans for 30+ years now ATS in springfield va, I did not add clutches in mine...but he told me he had done them for performance boats and added clutches for those apps..was weird, when did mine they were over 10 years old, replacing engines so they were on the floor so figured was the time...he took them down and found NO seal in the reverse piston from day 1..factory FU !!!! had noticed it took 5-10 sec to go into reverse never knew what was up...but was kinda hard to tell in the 50 gibson...
airjunky 12-08-2014 01:16 PM
Merc had a different spring for line pressure the original ran up to 25% more pressure when in gear ,and then there were the secret mods of the gen 4 575 and or 500s all I know on those is that they had a driveshaft coupler instead of the flat flange .so if you see one of those kicking around , grab it
FIXX 12-08-2014 06:39 PM
extend the pick up tube to more rear of the trans so its deeper in the fluid...with the picks be towards the front of the trans and all the azz end weight the boats sit nose high and the trand will suck air from time to time..
