They aren't bad but only 3" outlet. If I make adapter plates it would also be a good spot for O2 sensors of I go EFI.
Murf, If you use those risers, as long the first nipple flows all the way thru I would hook a hose from the top plug on the manifold to completely cool the riser and block the rear nipple.
| All times are GMT -5. The time now is 04:24 AM. |
