SBC to LS(style motor)
O2 sensors in crusader manifolds
http://www.classicglastron.com/phpbb...=5852&start=40
throw an LS2 cam in that 5.3l and it will be 350hp
well you need another alpha at least. that one is a 2.00 to 1 4 banger drive. and the steeper the gear ratio, the easier it is to snap the vert shaft with throttle. but a well built 1.5 alpha and a driver who doesn't need to do dragster hole shots or catch air at full throttle holds up ok. if you try hard enough you can break anything...
The last foiling trip I took last year was in s tri toon with a Yamaha 250hp outboard with 5 passengers it was full throttle pulling me 25 mph I believe with fresh toon fluff ,big bimini folded down light load planets aligned ect 42mph . You cram a 300 horse mill in the center pod of a tri toon make sure its a well built one welded together by a guy who had his game on
It may not be remotely possible and I'm sure someones already tried it ,but ..if you can make
Headers , why not adapter plates if you have the width .they make em for the bbf guys to enjoy the plethora of BBC manifold header options
I will(i think) be prefectly happy with 300hp in a toon. It really spends most of its time at 1500rpm just crusing the lake but it nice when I want to run upto Zorbas it wont take me 20 mins at WOT.
I also read that but he didnt say why.
I'm guessing it just easier that way then dealing with all the EFI. I will be keeping the EFI as I like a challenge I also think it will be cheaper in the long run with EFI, Intake, Carb and MSD box arent cheap. Then again not everyone is a cheap as me lol
