-   -   at what point are inconel exhaust valves necessary? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/321902-what-point-inconel-exhaust-valves-necessary.html)
dereknkathy 01-10-2015 08:24 AM
just tearing into my xmas present to myself. tired gen 6 L29. was shopping for heads for my mk IV and found a complete roller gen 6 instead. i am looking at under 450hp, over 112 lsa, under 5000 rpm engine use. and i don't even see inconels anywhere in 1.72 in. if an engine like this can live without, what is the second best choice?
sutphen 30 01-10-2015 10:20 AM
competition 6000 stainless from Ferrea.,or something similar.
MILD THUNDER 01-10-2015 10:30 AM
That engine should already have inconel exhaust valves. This is a replacement valve for that engine
http://www.race-mart.com/Sealed_Power-SLP-V2450X.html
http://www.napaonline.com/Catalog/Ca...50X_0204239889
dereknkathy 01-10-2015 12:54 PM
It is a propane gas engine. 10 or 12 quart pan with multiple outlets on the side of pan like it was set up to change oil while running. I think some kind of industrial pump or something.
MILD THUNDER 01-10-2015 01:09 PM
You sure its not a L21? Those had forged cranks in them.
dereknkathy 01-10-2015 02:10 PM
don't have the pan off yet. good possibility. the ex valve; magnet has no attraction until the very top maybe 1/4 inch of stem. like they used a malleable steel for the wear point at the rocker tip. you can see the change in color above the valve lock where the material changed.
sutphen 30 01-10-2015 02:27 PM
I believe the valves will be stellite and sodium filled.I remember using those valves from SBI.So thats why you see a cap like tip.
MILD THUNDER 01-10-2015 02:30 PM
Yes I think stellite material. Stellite is also a material used on the faces of some flat tappet lifters
dereknkathy 01-10-2015 03:06 PM
10114188 cast crank. oh well...got a 4-bolt roller engine for a nickel.
airjunky 01-11-2015 01:26 AM
Must use inconel valves with a zz502 cam if you want to retain the oem cast iron exhaust lol jk its late .i mean early .but really the inconel and super duty valves seem to resist losing thier heads much better if something goes ugly with the exhaust water .
