SSM 3. fits TRS upper?
And if so, is it a viable alternative to redoing the transom, relocating the engine and converting to Bravo? Or are they too old, scarce and pricey?
No. It doesn't fit TRS anything
Ssm 2 lower uses trs upper. Only thing you can use when swapping to 3's from trs is the trans itself, different tail stock and the boat.
And the 2 is pretty much extinct, right?
Yes
if they can be found, what props fit?
Jamie did you ever sell the #3s you had?
lil red has some #3's in SWAP section
Originally Posted by dereknkathy
(Post 4250652)
Team Archer on the board had some #2 lowers I think |
i have been convinced it isn't enough of a performance improvement to go from something where parts are hard to find(TRS) to something where parts have to be fabricated.
| All times are GMT -5. The time now is 02:08 AM. |
