-   -   Oil Temp or Water pressure gauge on single engine bravo boat? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/322248-oil-temp-water-pressure-gauge-single-engine-bravo-boat.html)
stimleck 01-19-2015 08:30 PM
I have one opening on my dash, which should I install? which is easier?
Thank You
TooLateVTEC 01-19-2015 09:54 PM
Oil temp is more important, IMO, between those two.
Atleast if the water pressure starts dieing off you can tell by the exhaust getting louder due to less/no water...theres nothing to tell you the oil temp may be too hot other than really low oil pressure.
Jeff P31 01-20-2015 02:00 AM
Oil temp is more likely to cause you trouble than water pressure my.02
stimleck 01-20-2015 01:09 PM
Is there already a location for the sensor on a stock 502 mag mark 5 carbureted boat?
fordf350 01-20-2015 01:46 PM
Thank You
I can't remember which company. But I think it is Livorsi has a gauge with oil and water in the same dial. If I see it again I will let you know.
wannabe 01-20-2015 03:43 PM
Thats funny because I would say water pressure. If the oil starts to get hot its usually from a blocked cooler.
Wannabe
jbraun2828 01-20-2015 05:33 PM
Water press would be easier to install, just need a water line from intake to back of gauge
vintage chromoly 01-20-2015 06:06 PM
Oil temp transducer should be mounted in the pan. We usually have our fabricator TIG in a NPT bung when we build up our engines.
vintage chromoly 01-20-2015 06:07 PM
Also, I like the oil temp as it lets you know when you can get in the throttle.
