valve retainer to seal clearance-thinner seals?
so, without any seals i have .750 of valve travel. with OE umbrellas i have .580 of travel. i would like to get 550 lift. is there an umbrella seal with a thinner roof to get more clearance without machining guides? 3/8ths stems. oval port.
i've seen some for chrysler 440's that are thin umbralla's.
Guide cutting tool isnt that expensive . https://www.youtube.com/watch?v=7aTXiay8M9k just take your time .GOOD LUCK!!!
or just run it without seals,you wont be the first guy to do it.
ordered a set of comp cams seals. should be in today. will report back with diff in thickness to OEM. i am sure quite a few of us want to go from 480 to 530-560 or so lift and it would be nice to be ok without needing machine work...
let me know,,I can dig some up at the shop and send them to you.
Originally Posted by mike tkach
(Post 4261086)
not crap.im dead serious.i have seen guys do it.alex who?i took a sbc apart one time that had 150 thousand hard miles on it.no signs of valve seals but it still ran good,just a little tired.
(Post 4261889)
When I raced circle track in the 1990's , It was pretty common not to run ANY seals . Different schools of thought , trends , ect.
I think just about all of the 87-95 sbc didn't use exhaust valve seals.
(Post 4261086)
back in my drag race days i ran blown alcohol,never had valve seals.i also have done some blown gas engines with no seals,i did not want to post it because lately around here if someone disagrees it seems to start a chitstorm so please dont tell me about what your super builder said.I DON,T CARE.
Originally Posted by Bawana
(Post 4261267)
Come on Mike.. why would you post crap like that? Someone on here might think its ok and actually do it. Your not letting Alex get to you.. are you?
the real diff is it takes 100k plus miles to make guides wear enough to smoke all the time. we don't generally wear engines out in boats, cept for sportfish that run out to canyon and back constantly. we either break them or get water in them and break them. but i am running a set of L29 truck heads with some guide wear so i am taking a belt sander to a set of new valve seals and looks like i get 600 free travel till retainer hits seal. will give me about 060 clearance. and on that note, once a hyd roller lifter is pumped up, is there any diff between lobe lift times 1.7 and the actual distance the valve travels?
cheeper lifters can bleed down so while the 1.7 ratio does not change,the actual amount of lift can be a little less.
OEM lifters qualify as cheaper ones? about what percentage do they lose? and long as i have you on the phone, i think you have a set of mag standard pistons-rods you are willing to part with?
Originally Posted by dereknkathy
(Post 4261970)
Originally Posted by MILD THUNDER
(Post 4261944)
Contrary to what some say, Mike is no rookie. Abones is another extremely knowledgeable man who has been around engines a long time. No "crap" there.
Also I am not one of the peeps that think Mike is a rookie... I like to read all his posts... not saying that I agree with all of them,LOL... But I can tell he has been around the block. (no pun intended) |
The beauty is we all don't need to agree, but we all can learn something from each other.
Can't believe nobody has a opinion on sucking oil in through the intake valve, and raising the chance of detonation.
(Post 4262766)
(Post 4262191)
i read a line in a car forum i thought was funny.."arguing on the internet is like participating in the special olympics. even when you win you are retarded!"
Originally Posted by endeavour32
(Post 4262839)
Sounds like something that I said- but has harshly jumped all over for saying it! Thanks for using my words…...
Why don't you have a glass of cranberry juice. It helps my wife on those heavy menstrual cycles. |
(Post 4261889)
(Post 4261933)
| All times are GMT -5. The time now is 10:13 PM. |
