-   -   Thunderbolt IV ignition bracket is +12v???? HELP (https://www.offshoreonly.com/forums/do-yourself-boating-budget/323797-thunderbolt-iv-ignition-bracket-12v-help.html)
Nmbr1GMfan 03-08-2015 10:06 AM
My bracket that bolts to the right side rear head and has the main plug with a relay and a breaker is +12v, the whole bracket is positive. It does have the plastic isolators installed but this doesn't seem right at all.
Jonesyfxr 03-08-2015 10:59 AM
It's reading positive because you have a weak ground. You have to make sure all your ground wires are clean, tight, metal to metal connections with no paint or corrosion.
dereknkathy 03-08-2015 11:39 AM
i think you also have a short between main power wire and that bracket. it needs to be grounded, but you shouldn't see volts on it.
Nmbr1GMfan 03-08-2015 10:10 PM
It was a wire touching the metal part of the relay. Dont know how it didn't screw something up but fixed now.
