Gil exhaust center to center dim
I have very little center to center side by side I am working with on boat restoration. Like 33" centers max. Anyone know for sure if that is a problem with Gil's
Tks John |
Originally Posted by getrdunn
(Post 4283561)
Tks John So unless I am way off I would have to say center to center dim on Gil's would be closer to 34" |
With std deck stock heads yes, raised port heads 34", tall deck 34.5 iirc
Thank you. I was measuring as you posted however that kinda confirms. Do you happen to know what stellings are? From what I understand there is black and green series? Green are the larger tube and come forward and sweep back. Correct me of I'm wrong. I am in a dilemma with such narrow centers. CMI etops I am coming up with 33" measuring same way.
Make sure you line up the crank pulley across, there will be stagger in the exhaust ports from engine to engine. I believe e tops are 33 1/4, stellings black I believe fit with 33" centers, as do some other models but I'm not sure which particular ones. I'm rigging my boat wider now as to not run into this issue. My last boat at 34" can't get tall decks in.
Originally Posted by Unlimited jd
(Post 4283649)
Ya this narrow center to center sucks. Doesn't leave you with many options. If you happen to know on the different stellings I'd appreciate the info. Tks again for the help. I was gonna call a number I found from an old post for stellings. Not sure if it's still good or not. John |
| All times are GMT -5. The time now is 06:55 AM. |
