-   -   Old school throttle conversion HELP (https://www.offshoreonly.com/forums/do-yourself-boating-budget/324849-old-school-throttle-conversion-help.html)
getrdunn 04-06-2015 07:53 PM
1 Attachment(s)
Hey guys I wanted to swap out original throttle assm to new set up. i have the merctrans with the electric shift and would like to keep unless there isn't any way to use the new shifters in this manner otherwise I can always run cables or just keep current set up but would rather not. I haven't taken the old throttles out yet to see what exactly activates the selonoids on the merctrans.
Any insight would be great.
Tks John
northernoffshore 04-06-2015 09:39 PM
get rid of the electric shift and convert to cables...http://www.kcmarinetr.com/MercTrans-Facts.aspx
getrdunn 04-06-2015 09:52 PM
Know that I read that I recall seeing it years ago however forgot about the issues with them. Will switch to cables for sure. Just need to place a wanted ad for cable brackets. Will need cables regardless for changing out trans next winter.
Tks
John
koryk 05-12-2015 07:51 AM
What cables do you use for this conversion? Anyone have a part number or a link?
bcfountain 05-12-2015 02:18 PM
I cannot tell anything about the merc trans or the electrical part of that transmission,,,,but can tell you this.i had those same shifters on my ten meter,,,,,i hated them with a passion.i changed them out with a livorsi control.the cable ends were different and the dash hole had to be inlarged,,,,,other than that that's all I can tell you other than you will like the new shifter better.
getrdunn 05-12-2015 09:02 PM
It been a while since I ordered my cable for new throttles and shifters however it seems like they were 33c and I ordered from Rex marine.
koryk 05-12-2015 09:11 PM
Thanks getrdunn!
