complete overhaul on 38 scarab
7 Attachment(s)
i thought i maybe able to past on some info from my going project. started with going to freshen up the 510 bowties in boat.
pulled motors , found the motor had came apart at one time. skirt were pretty scuffed up, and a bent 7/16 rod. next found transom was shot and main stringer. i will be replacing transom and stringer, repowering boat with pair of 547's. will post photos as i go, [ATTACH=CONFIG]539780[/ATTACH] [ATTACH=CONFIG]539781[/ATTACH][ATTACH=CONFIG]539782[/ATTACH][ATTACH=CONFIG]539783[/ATTACH] [ATTACH=CONFIG]539784[/ATTACH] [ATTACH=CONFIG]539785[/ATTACH] [ATTACH=CONFIG]539786[/ATTACH] |
Somebody got a deal on diamond plate lol, looks like a big but rewarding project, good luck!
1 Attachment(s)
Originally Posted by Unlimited jd
(Post 4290907)
funny,,,but its not aluminum,,,its a fiberglass board, with the look like diamond plate pattern. the photo shows a the frt side and then the back side of another piece. yes,,this will be a big project, but i enjoy fabricating, making stuff, but i will enjoy going for the first blast.!!!! i plan on enjoying this boat till the end...................... flash...........out |
1 Attachment(s)
they used a lot of that on the Scarab line all through the late eighties and early nineties count your blessings the stuff in my 38 is red white and blue lol. I pulled a mold off a full sheet of polished diamond plate so I can make it, kinda handy but not as popular as it was back then. I did some in carbon fiber
Good luck with that flash. I did the same thing to my scarab two seasons ago. I decided to ditch the diamond plate and just painted white. Lots of work ahead.
1 Attachment(s)
steering done....
had to mount inside,,,no room outside..[ATTACH=CONFIG]543850[/ATTACH] |
3 Attachment(s)
setting up the new engine mounting....note the alum angle///
[ATTACH=CONFIG]545099[/ATTACH] [ATTACH=CONFIG]545100[/ATTACH] [ATTACH=CONFIG]545101[/ATTACH] |
Looking Good!
Did my engines and transom/stringers two years ago as my all winter project...lots of work to say the least! I see now why these guys charge 4 to 5k to replace the transom only. My 31 Excel didn't have any of the diamond plate material in it...this is the first I've seen it. It's a labor of love for your boat and you'll be happy when your done and know you have a solid boat and nothing to worry about in rough water...keep up the good work!
4 Attachment(s)
thanks scarab31....was alot of work,,,just more time then anything...ended up doing transom and all stringer...
time to assemble 547s...get ready for next yr... [ATTACH=CONFIG]546544[/ATTACH] ......[ATTACH=CONFIG]546545[/ATTACH] [ATTACH=CONFIG]546546[/ATTACH]........[ATTACH=CONFIG]546547[/ATTACH] engine compt done...time for motors.... |
| All times are GMT -5. The time now is 10:21 PM. |
