-   -   Coupler question (https://www.offshoreonly.com/forums/do-yourself-boating-budget/325797-coupler-question.html)
the mayor 05-02-2015 03:45 PM
Coupler question
Getting ready to set my engine back in. Cleaning the coupler up it appeared to have a thin bead of silicone applied to the side that goes to the fly wheel just inside the bolt holes. Is this common practice or could it be the coupler is going bad. Also the bolts I removed are grade five, should they be grade eight.
F-2 Speedy 05-02-2015 03:50 PM
I don't see a need for a sealer on a coupler, if you change bolts, you need to make sure they are a shouldered bolt like the in it now to properly center the plate, personally I don't see a need to change bolts
the mayor 05-02-2015 04:21 PM
They are not shoulder bolts. Just Plain 3/8 hex head bolts. Thats what I took out when I removed the engine.
F-2 Speedy 05-02-2015 05:14 PM
1 Attachment(s)
They should be like these, the hole in the coupler is .372 a 3/8 bolt is .356 this will let the coupler move around and not be centered & may cause vibration
the mayor 05-02-2015 05:28 PM
Definitely not what was in it. I will be calling the local Mercury dealer Monday.
F-2 Speedy 05-02-2015 05:58 PM
ARP makes them if you have a local speed shop
the mayor 05-02-2015 09:02 PM
No local speed shop. Jegs or Summit have them.
Bawana 05-02-2015 10:12 PM
McMaster Carr on the bolts, and I would never silicone the coupler.
dereknkathy 05-03-2015 07:05 AM
loctite? hell yes. flywheel bolts too.
the mayor 05-04-2015 04:10 PM
Called the local Mercury dealer. They gave me the same part number I found on the Web last night 10-37612. Went to pickup the bolts after work. No shoulder just 3/8 - 16. 1 1/4" hex head bolts grade 5. They were in QuickSilver sealed bag. Counter guy looked around and got a tech involved that's all he has used. He's not sure maybe they come with an HP coupler.
dereknkathy 05-04-2015 05:04 PM
stick an outdrive input shaft or alignment tool in it and spin it with starter and see how centered it is...
the mayor 05-06-2015 04:27 PM
My coupler the holes are .392. The flywheel has cobores that are .375 a difference of. 017 even if the bolts had shoulder it could only be .375 to fit in the cobores on the flywheel. I made some stepped pins for three holes then installed 3 bolts then pulled the pins and installed the other 3 bolts. I will check the alignment when I install the engine.
