-   -   Thermostats in 502 blowers (https://www.offshoreonly.com/forums/do-yourself-boating-budget/326025-thermostats-502-blowers.html)
PorscheSpeed 05-08-2015 05:50 PM
New boat has 502's with B&M 174's and super chillers. Upon further inspection neither engine has a thermostat in it, or a restricter. Neither engine built any temperature when out for a run last weekend (very cold lake water)
Should i have thermostats or a plate to reduce the flow rate??
mike tkach 05-08-2015 08:39 PM
NO.some will disagree but i like to keep the heads as cool as i can to reduce the chance of detonation.
MILD THUNDER 05-08-2015 09:17 PM
ESPECIALLY running a tiny blower like that 174 on a 502ci. :picard1:
endeavor1 05-08-2015 10:29 PM
Do you feel the same on a NA motor? Reason I ask is moving from TN and running in the river to Texas lakes, I'm considering getting rid of my stats again. Iron heads on my 555s. Last year without them I had trouble building heat and oil temps. After going thru the motors this winter I reinstalled them thinking I'd be in TN but a job change brought me home to TX. Input, thoughts?
mike tkach 05-08-2015 10:41 PM
it depends on things like heads,compression ratio etc but not as critical as a small blower on a 500+ inch engine.
PorscheSpeed 05-09-2015 07:43 AM
I had no issues building oil temp (i run oil thermostats) but i never build any water temp at all.
Black Baja 05-09-2015 01:34 PM
Just because the water exiting the engine has no temperature does not mean that the metal surface area in the engine is being cooked at all.
Black Baja 05-09-2015 01:37 PM
Just because the water exiting the engine has no temperature does not mean that the metal surface area in the engine is being cooled at all.
indysupra 05-09-2015 02:09 PM
Procharged efi 509's no stats. All is good after three years. Mine in warmer lake temps and running hard will get up to 115
MILD THUNDER 05-09-2015 06:50 PM
Oh geez. Here we go again with the temperature debate. :throw:
