Can I eliminate the Y Pipe
Is it possible to eliminate the Y pipe instead of capping it off?
Keep in mind that you will have to pull the drive and engine to remove the Y-pipe. I simply capped mine. That way if I decide to go to a switchable exhaust I still have the option - but depending on your intentions (marine headers, dry exhaust, etc), it may be cleaner to remove it.
| All times are GMT -5. The time now is 02:03 PM. |
