-   -   Anybody run their 2nd ring tighter than the top ring (https://www.offshoreonly.com/forums/do-yourself-boating-budget/327935-anybody-run-their-2nd-ring-tighter-than-top-ring.html)
phughes69 06-30-2015 10:43 AM
Does anybody run their 2nd ring gap smaller than the top ring. I'm trying to figure out if this is a good idea. My old rings had a top gap of .031 and the 2nd was .030. The motor is a 4.250 bore 454 BBC with twin turbos
Black Baja 06-30-2015 10:51 AM
I've never ran the second ring tighter. When it comes to stuff like ring gap the best thing to do is talk to the manufacturer and see what they suggest. Tell them in detail what the motor is. How it will be ran temperatures. Water pump no water pump. Proper gap and wall finish can make or break a motor as far as making power.
Unlimited jd 06-30-2015 12:39 PM
All of your rings were .030 and .031? That's pretty good for ring gaps, pretty lucky if cylinder to cylinder is within .003
snapmorgan 06-30-2015 01:10 PM
There will be a sheet with the rings to yell you where to gap them depending on application
14 apache 06-30-2015 01:36 PM
This was old school thinking. The rings work better with the second gap bigger.
Budman II 06-30-2015 03:22 PM
I'm running Mahle forged flat tops in mine - the techs with Mahle recommended .022 top and .024 2nd if I recall correctly. He told me that they were running the second gap larger nowadays to reduce ring flutter. .030 sounds like a pretty big gap, but that may be due the the use of a power adder. I think you want to run bigger rather than smaller gaps on a marine build anyway. Do some homework on this - you definitely don't want to bust a ring or ringland, but you also don't want to end up with a ton of blowby and excessive oil consumption.
Black Baja 06-30-2015 03:22 PM
Especially when you are really stuffing the motor. An xtra .010 o the second ring can be worth considerable horsepower.
airjunky 07-01-2015 07:59 AM
I think the mahle guys are anticipating some "trapped pressure " between 1and 2 to provide some ring seal and oil control on this one also. Lots of tedious measuring for you it sounds like.
It will all be worth it when you fire that thing off and flog it for years to come.
