-   -   fuel pump oil. where to add? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/328345-fuel-pump-oil-where-add.html)
Z06 FAN 07-10-2015 07:35 PM
I took my boat in to get the engine scanned and that all checked out fine but the tech said there was fuel in the pump where there was suppose to be oil. He said to suck it out and add 80w90 to it. I cant find where the fill is for this and was wondering if someone could point me in the right direction?
airjunky 07-11-2015 08:33 AM
The side of the raw water pump has 2 flathead screw drain and fill plugs , use green drive lube if u have on hand
AllDodge 07-11-2015 08:55 AM
Could be one or two plugs depending on the year. Here is a link which others discussed
http://forums.iboats.com/forum/engin...mp-maintenance
Griff 07-11-2015 11:40 AM
If it only has one fill plug, you should really just dump it out. Trying to suck it out is impossible and you'd be lucky to get half the contaminated lube out.
