-   -   Anyone found a molded cooling hose for rear mount cooler to crossover??? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/328490-anyone-found-molded-cooling-hose-rear-mount-cooler-crossover.html)
fantastixvoyage 07-14-2015 12:24 PM
Seems I have seen builds that have a molded 1 1/4" hose going from a typical rear-mounted aftermarket oil cooler up to a crossover. Hate to run generic hose and just bend as needed, cleaner look if I could find the right hose. Any thoughts?
Trying to go thru the schematics on mercruiser parts site but nothing coming up yet.
Black Baja 07-14-2015 02:44 PM
Hardwall 1-1/4" with the steel wire.
fantastixvoyage 07-14-2015 03:38 PM
That's really only needed for the suction side of the seapump. I'm looking for pre-molded like OEM hoses. Swear I've seen builds that had a setup that work with the crossovers
BUP 07-14-2015 03:44 PM
corrugated flexable water hose the correct diameter.
Team Archer 07-14-2015 03:48 PM
Get your self a Gates Hose catalog they have a pictures of all the hoses by size. That's what we use
BUP 07-14-2015 03:52 PM
Or Trident or MPI
Cole2534 07-14-2015 04:11 PM
Good idea! I'd love to have one between my bellhousing mounted oil cooler and my sea pump.
Shibby1485 11-05-2015 06:24 PM
Any luck? I'm looking for the same hose a molded hose to go from bell housing mounted cooler around to the crossover, this came up in a google search.... Also need the sea pump to oil cooler hose, what are you using for that?
delsol 11-06-2015 06:09 PM
Exactly what team archer said....
Most have a pic and dimensions in their catalogues
253 11-15-2015 10:31 AM
I would like to have those hoses also, currently using hardwall hose .
