kiehaefer trim tabs fliud
i was looking thru some post as to what fluid for my kie trim tabs...thought it would be atf..........
BUT,,,,some people posted it was 10-40 motor oil!!!!!!!!!!!!!!!!!!!!!! WRONG.. as stated on the instruction i have from 1989,,,states clearly use dextron atf only .end of story. |
ATF, SAE 30, motor oil, It all works the same. I would imagine that the atf works better because it has a lower viscosity. If it has dexron in it now, stick with it, but in the end any kind of motor oil or hydraulic type fluid will work.
| All times are GMT -5. The time now is 02:09 AM. |
