Originally Posted by ICDEDPPL
(Post 4387508)
Wouldn`t that make the boat quite a bit harder to sell later?
Originally Posted by thirdchildhood
(Post 4387527)
I like the idea but I'd keep the head. If you ever did want to overnight you'd just need a roll of foam padding and a bag of sheets, blankets and pillows.
Thanks again for all of you for your thoughts, ideas and suggestions. I genuinely appreciate all of them. These are not our boat but gives an idea of what I have bouncing around in my mind. http://i63.photobucket.com/albums/h1...psegoahodd.jpg http://i63.photobucket.com/albums/h1...psuwodx28v.jpg Thanks again everyone and Merry Christmas.........john |
I tried to do it. It was way too much work and I eventually went back to glue on carpet. Mine was biax mat and after I got all the old glue off I did not want to try to fill and sand and sand and sand.
I did manage to get all of the old glue off. 3M makes an adhesive remover that works pretty good. It comes in a red can in some states, some states you can only get the new formula. Brush it on, leave it sit, and then scrub off the old glue with a grill brush. |
The Donzi 22 Classic has the entire front blocked off with only a small storage bin. I needed storage space so this is what I did. I occasionally overnight in it at PIB and have a foam roll cut to fit and a nylon duffel bag with sheets, blankets and pillows. It's very cozy with a girl and toilets and showers are on the dock. All carpet in the boat snaps in. This mod added 15 pounds to the weight but if I pull out the front carpet I am under original weight.
http://i763.photobucket.com/albums/x...es410Large.jpg |
even in the engine rooms I did I used thinner to wipe down glue pellets and sanded, did not try to smooth out, when painted looked fine..heres a shot, the sides were carpeted, also another trick I used, on the floor area's, on the last coat of paint I sprinkled the paint flakes used for garage floors, looks great, makes more non-skid and hides the hell out of foot prints/dirt/etc between clean ups..
http://i227.photobucket.com/albums/d...ps571e8500.jpg |
(Post 4387814)
Originally Posted by ezstriper
(Post 4387841)
http://i227.photobucket.com/albums/d...ps571e8500.jpg I'm not afraid of sanding as we've done a number of boats where we've pulled the carpet and glue out and laid carbon fiber down. It's a ton of work but the results I think are exceptional http://i63.photobucket.com/albums/h157/jrork/191.jpg http://i63.photobucket.com/albums/h1...psdo83bsgd.jpg http://i63.photobucket.com/albums/h1...psdvmakyq5.jpg http://i63.photobucket.com/albums/h1...psbm2rok99.jpg We're in the process of restoring an old show boat with carbon and all new end core balsa that is going to the be the best yet! Thanks again guys and Merry Christmas |
Originally Posted by c_deezy
(Post 4387779)
If it is rough another idea is you could lay down a layer of veil mat or if its really bad some 3/4 CSM and then the veil mat, and then sand and gel over that.
Nice work on the carbon, that looks awesome. |
(Post 4387980)
Nice work on the carbon, that looks awesome. Thanks for the kind words on the carbon. I'm am more of the grunt labor and my son is the finish guy. Getting the weave to lay and stay straight would push my patience factor thru the roof. |
| All times are GMT -5. The time now is 08:39 AM. |
