Zero effort shifters
Old 02-12-2016 | 10:13 AM
phughes69's Avatar
The controls are pretty simple as Phragle stated. If your throttle is creeping back, did you do something to the carb? New carb? new throttle return springs? The neutral safety switch is a simple micro switch. You can adjust by bending the lever towards the switch. Use a volt meter set to buzz on ohms and check continuity when shifting between forward and neutral. The picture of the shifters shows the small balls and springs circled in red and the nylon plastic slide in blue. Like MT said use lithium grease to hold the balls in place when reassembling it.
Attached Thumbnails Zero effort shifters-zero-effort.jpg   Zero effort shifters-neutral-safety-switch.jpg
phughes69 is offline
Old 02-12-2016 | 12:20 PM
Thanks guys for all the info. The cables are not tight/stiff and hard to move in any way. When moving the sticks forward on the port side you feel the ball cilck into place and not so much on the starbord witch is the one if you let go of them will fall back a little differing rpms slightly from port motor. Not a huge deal but bugs me knowing it happens. Ocd issue lol
1989mach1 is offline
Old 02-12-2016 | 12:24 PM
But the safety switch needs to be adjusted or replace if bad because I don't want to be some where and have it not want to start.
Old 02-12-2016 | 12:54 PM
Look down in the boot. There should be an allen. Just back it off a turn or two and see what happens.
Keith Atlanta is offline
Old 02-12-2016 | 08:17 PM
phughes69's Avatar
Keith, Where is the allen inside the shifter and what is it for? When I put Zero Effort shifters in my boat I had a 3 engine unit that I converted to a two engine unit and I don't remember there being a allen screw?
Old 02-12-2016 | 09:13 PM
THe allens he mentions are in the high end stuff livorsi, etc...not the basic zero efforts....
phragle is offline
Old 02-12-2016 | 10:19 PM
I just bought a few sets of these controls to build a new set for my boat as well as polish and resell. There are 2 detent balls per throttle, I believe phragle may have mentioned that, to lock the throttle in position. Upon taking one set I bought apart I noticed that someone before me had taken one of the detent balls out of one of the throttles but the second one had both. This for sure will make the one handle slip back. If you didn't buy the boat new there's a good chance someone could have had them apart and maybe lost parts for it when it went back together.
89Mach1 is offline
Old 02-12-2016 | 10:55 PM
As soon as I can get into the boat and take it out there dash I will look at all of these things. Thanks for all the help.
Old 02-13-2016 | 12:12 AM
Of course you do realise that a genuine hard core powerboater would simply bungy cord the sticks to the dash, run her balls out and not have the problems you are experiencing,...
phragle is offline
Old 02-13-2016 | 07:42 AM
Lol ya its not often I take my hand off the sticks and the sticks off the dash. Only to a just the tabs but knowing it does that bugs me lol
