Just curious, what are the specs roughly on say a 741 or 651 cam, they seem to be talked about a lot, and how do they fare reversion wise? Never really hear what exhaust folks are using with them.
Edit:looked up the specs,still curious about reversion in 651 or 691 cam. Looking at something similar except in a solid roller |
Originally Posted by hotjava66
(Post 4412154)
because the duration is so small the 109 lsa is ok. I concur totally. It's just an oddball configuration that will throw people unless they look at the entire cam profile. I think the .050" duration is like 196 on the intake for this cam. |
Originally Posted by Trash
(Post 4412308)
What matters is how long the exhaust valve is open ATDC during overlap. If you do a search, I have many cams, including the popular blue motors, showing specs including overlap #'s.
Even if not shown, overlap is easy to calculate - it's the # of degrees from when the intake opens to when the exhaust closes. ie: IVO to EVC. Way back when, Crane said it's easy to get into reversion issues when overlap at .050" specs exceeds 6 degrees or more. Again, if not stated, most cam companies with show events at .050" also. Take how many degrees from IVO at .050" to EVC at .050" |
(Post 4412308)
sb,i was going to include that info but i am way to lazy tonight.
Originally Posted by mike tkach
(Post 4412406)
Tomorrow, being Monday, I had to release some info from my limited grey matter so I'd have a few brain cells free'd up for work . hah ! |
Originally Posted by SB
(Post 4412403)
Yes, it's 196/206 at .050" with 109LSA. Overlap at .050" is a negative number. It's a truck cam...literally.
It does idle smooth. Pulls strong in the midrange then falls on it's face above 4000-4200 rpm. |
(Post 4412401)
| All times are GMT -5. The time now is 07:38 PM. |
