Power steering pump seal kit
My pump has a slow leak. I believe it's the pump/reservoir seal. Found this kit:
http://www.ebay.com/itm/SAGINAW-POWE...tRroLu&vxp=mtr Anyone know if it would work? It's for my 1990 Fountain. |
i think it will.merc used gm pumps,nothing marine about it.
I have been told in the past it was the same pump but the relief valve screwed in back is different ..Do you know if this is true or false ?
Ok, thx! For $11 can't go too far wrong.
Not sure abt the relief valve. Would you want more or less press in a marine application? |
i am not sure but if i remember correctly it is the same.
the pressure regulator is different(big nut on rear with valve and spring under), seal kit will work, main pump the same, was told but I never verfyed that they used a bearing instead of a bushing for the marine pumps and they were done by AGR
| All times are GMT -5. The time now is 04:01 AM. |
