-   -   exhaust air cylinders [replacements?] (https://www.offshoreonly.com/forums/do-yourself-boating-budget/337066-exhaust-air-cylinders-%5Breplacements-%5D.html)
misslead 05-04-2016 04:39 PM
got harrassed by the boat police at the fuel dock
little air compressor working like a champ old air cylinders seem to be not working air leaks around shaft . any replacement ideas that arnt 70 bucks apiece from gaffrig?
MILD THUNDER 05-04-2016 04:41 PM
Take them apart. Theres O-rings in there. You can get the orings at most hardware stores.
Tinkerer 05-04-2016 06:37 PM
That and don't lubricate them with oil - use dish soap - just a few drops into the air fitting. I tried oil on mine years ago and it made them worse, Talked to a MERC guy and he told me to use dish soap.
Griff 05-04-2016 07:52 PM
I had the same issue a couple years ago. I replaced the internal O rings as MT said and problem solved.
They look like one piece, but the endcaps do unscrew.
misslead 05-05-2016 07:03 AM
will take them off today and try that thank you for the help
new ones are like 70 bucks each!
92nsx 05-05-2016 07:43 AM
This was from another thread of the same subject. I saved the info, just not the thread.
Parker 1.06 bore, 2" stroke, 5/16" shaft spring extend air cylinder,
parker 1.06RSR02.0
Google/Amazon and $29 for new ones :boat:
http://www.amazon.com/Parker-1-06RSR.../dp/B00BUA72P0
MDonziM 05-05-2016 09:39 PM
I replaced mine a year or two ago for less than 1/2 Gaffrig price, I'll try to find the receipt. On the subject, has anyone replaced the little air pump/compressor? I took mine all apart last year and it failed again after a couple days... Very prone to salt.
MDonziM 05-07-2016 02:50 PM
Mine are Custom Marine # D 88168-A
dereknkathy 05-08-2016 08:27 PM
35 bucks at harbor freight. http://www.harborfreight.com/catalog...compressor+12v
northernoffshore 05-08-2016 09:00 PM
rubber hose sliced down the middle held mine closed during storage
