Mix Interlux Bilge Coat White w/ Rustoleum White?
Has anyone done this? I refinished a floor in the engine compartment that had a bunch of screw holes from over the years. Painted it Rustoleum white with some hardner. It's too white. I used the Interlux Bilge Coat in the past, and it's too yellow. I need something in between and was thinking about mixing the two to get the color I need? Anyone tried this before?
sounds like an experiment you need to try and see what happens.of course,outside the boat and in a small amount.report back what happens.:D
try mixing brown with with but i would stay with all rustoleum, they also have a almond but you would need to mix with white as well
Ok, i'll get some almond paint and mix a bit in. I'll feel better about that than mixing with the Interlux.
I painted it last night, 10pm. Was about 65 in my shop. I mixed in 2 oz of the hardner with 1 qt of the white. This morning was 55 in the shop and stuff was still wet. It's supposed to be up to 72 today so I have the door cracked. Hopefully this stuff dries. I was expecting the hardner to make it dry even at 60 degrees. I wanted to put on another coat tonight, but if this stuff is still tacky, may not be able to......... arg. |
Did you mix it well, put enough in and let it sit for 20 minutes before using it?
I also use 4 parts white to 1 part almond to get that "right" bilge color. |
Mixed it well yes. I don't see the point in letting it set for 20 minutes unless a guy wants it to go on thicker. Shouldn't effect dry time??
Put a fan in there to move the air around. With thin coats of resin that don't like to kick this really helps.
I have a question- The hardener that you mix in the paint; is it the same as the hardener used to mix up epoxy resin?
http://i.ebayimg.com/00/s/NTAzWDUwMw..._id=8800005007
I was told you let it sit for 20 minutes so it can react or "kick off" before painting with it. You really need to do that. Also if you put a sealed lid on it wont harden up in the container for hours if not for a day. It has to off gas to harden and is why a fan is a good suggestion to help drying. And just a FYI, don't spray paint mixed with the hardener. There's chance it may kill you without the proper fresh air gear. |
| All times are GMT -5. The time now is 10:09 AM. |
