Which fluid for the trim system on my 96 bravo
Is the Merc powersteering/trim the correct stuff? I read somewhere it could also be 0-30 oil.........
Stick a piece of something in there and see what color the fluid is.
It's a runny dirty brown right now. I think it's power steering.... I dumped it all out right now. I'm changing over to the GRP bracket and reservoir. I'll go with the Merc stuff.
10 w - 30 motor oil
Every boat I've ever had used engine oil. If I've had to add oil, I used 10w-30.
I'm going to change all my trim fluids out next week, and I'll use 10W-30 motor oil
No kidding? Trim tabs too?
Originally Posted by Baja Rooster
(Post 4441376)
Not sure about other brands but my Dana tabs take 30wt oil.
Padraig |
I never mentioned anything about trim tab fluid the OP asked about the trim reservoir for the outdrive. I have used 10 w 30 motor for 25 years for the Merc side.
Some tabs for fluid use ATF as well |
ATF. They react faster
Originally Posted by Padraig
(Post 4441436)
Padraig |
Mercruiser recommends for trim tabs. 10w 30 or 10w 40
http://www.ibs-ny.com/freedom/Engine...Tab%20Pump.pdf |
I use 30wt motor oil. If I end up with a pump that's a little slower than another pump I put thinner oil in it. This usually helps to speed it up a little...
I've always used power steering fluid. It's always worked well and reponds quickly. When it comes right down to it I guess you can put in what ever you want. MerCruiser power trim amd steering fluid, 10w30, 10w40, power steering, atf, etc. Use what you have best results with.
For those having motorcycles, Fork Oil @ 15W works great as well too for trim pumps.
Originally Posted by class6
(Post 4441446)
I ended up putting the Mercruiser power trim fluid in.
I've used ATF in both trim and tabs and never had an issue. I also use ATF for my steering.
I have found you can use either one.(power steering or ATF)..you probably wont notice any difference since they are both hydraulic fluids and both are in the neighborhood of a 20W oil in viscosity depending on who makes it....the advantage ATF has is in the detergents and friction modifiers in the oil to help keep things clean and keep heat buildup down.....Since the trim/tab pumps are not constantly being used like a trans or a power steering pump, its not really required for them....so basically any good hydraulic fluid will work just fine
Oil depending on the weight may slow the pumps down a little... |
| All times are GMT -5. The time now is 05:31 PM. |
