Carb tuning
Intake manifold vacuum is irrelevent if the carbs are not boost ref. The vacuum under the carb, but above the blower, while running on plane, is what you want to monitor. Reason a 10.5 pv is typically used, is that it typically opens very early, just like a boost referenced pv would. You can adjust where the pv opens depending on the readings you get. A 10.5 is a good setup to start with. It will open early, and pretty much leave you to focus on jet changes only while up and running. That divide by 1/2 of intake manifold reading and pick a PV, is useless in your combination.
