-   -   Holley electric fuel pump (https://www.offshoreonly.com/forums/do-yourself-boating-budget/338931-holley-electric-fuel-pump.html)
Baja 240 sport 07-04-2016 05:30 PM
I have a 454 mag, 385 h.p. Holley 750 double pumper. I am using a Holley Black electric fuel pump. It went bad the other day and i am looking to replace with another Holley pump. I see they have 2 others besides the Black. The Red and the Blue. I know the Red pumps the lowest amount of fuel, then the Blue. Just wondering if i could use either the Red or Blue, besides the Black which seems to be an over kill in my opinion. Any advice would be greatly appreciate. Dan
MILD THUNDER 07-04-2016 08:11 PM
Personally, I wouldn't use any of those holley electric pumps.
ROB FREEMAN 07-04-2016 09:04 PM
had nothing but problems with the holley pumps in the cig , replumbed my eikert upgrade seawater fuel pumps . haven't had a problem since good riddens
Rookie 07-04-2016 10:13 PM
I have been running Mallory 140's for years. Look at the Mallory 110. They are easily rebuild able and internally regulated at 7lbs.
Baja 240 sport 07-05-2016 05:13 PM
Thanks for the advice
Baja 240 sport 07-05-2016 05:14 PM
Thanks, for the advice. i appreciated
Baja 240 sport 07-05-2016 05:15 PM
Thanks i will look into that.
MILD THUNDER 07-05-2016 09:46 PM
Those mallory pumps are pretty darn reliable pumps. Is there a provision for a mechanical fuel pump on your engine ?
conneroutlaw 07-06-2016 04:06 AM
Here on the site, they suggest an aeromotive fuel pump with my application and it has worked great
Baja 240 sport 07-06-2016 02:45 PM
Thanks for the response. There is no provision for a mechanical pump, can only use electric. I used the Holley Black pump that was installed 9 yrs.and it worked fine. Need a new pump , but thought something like the Black pump was over kill for my motor and carb setup. Now just looking what will work best. Thanks again.
