Merc 454 Water Circulation Pump
Guys,
I am looking to do some Engine updates - could use a recommendation on replacement water circ pumps....any decent quality aluminum units that will bolt right on would be appreciated. engines are closed cooling - carbed basic units. Jegs or whatever numbers would be ideal. Thanks Swampy |
i would not use a automotive circ pump,they are different.if you need a new circ pump go with a merc or sierria,jmo.
Sierra makes them for Merc believe it or not., Its is true.
I should have a new order of circ pumps coming in about 2 weeks all made in the USA and all Marine rated. I order 25 to 40 at a time depending on what date of the year it is. Currently sold out. I have not had any issues with these USA made circ pumps and have been using them for the past 5 years, Again they are made for 100 % marine use. . FYI. |
Why wouldn't an automotive type pump work in a closed cooling system?
Just wondering out loud. ken |
it would not know the difference
Originally Posted by Swamplizard
(Post 4457195)
Guys,
I am looking to do some Engine updates - could use a recommendation on replacement water circ pumps....any decent quality aluminum units that will bolt right on would be appreciated. engines are closed cooling - carbed basic units. Jegs or whatever numbers would be ideal. Thanks Swampy The only hard anodized aluminum pumps I could find where for small blocks. |
different materials used. Most impeller designs are bidirectional and the blade configuration. The internal bearing used is different and stouter as well. S S backing plate for a jist of this
thanks BUP
BUP,
i'd like to get a circulation pump mark 4 short (1984 330 ) also need 3 groove pulley can be any condition, just need for dimensions will send pm in case you miss this |
as long as its a std rotation and closed cooling automotive pump is fine...
| All times are GMT -5. The time now is 08:20 PM. |
