Looking for a BUP archive............
I'm pretty sure that BUP posted a Merc technical bulletin regarding a leak at the inner transom plate. I'm pretty sure I've had this leak for years, but its been slow enough that I never got around to addressing it. I'm wanting to fix it this fall. I've searched OSO and the net and can't seem to find anything. Maybe I was just dreaming this?
Rutrow what did I do now ? I hope I WAS NOT IN YOUR DREAMS. ----- have to mess with you haha
Man there is so many SB's I have to think of the SB numbers and see if I can post it. Sorry for now but thinking. |
Bump for the real SB. :funnypost:
yep SMALL BLOCK or is it Service Bulletin
here is one I posted in the past. These a lot of times are not found for trying to track down very hard to find water leaks. Hopefully this helps whomever as well.
http://www.boatfix.com/merc/bullet/88/88_06.PDF |
Thanks BUP, I will check that one out also. I think the one I dreamed about was an SB about a defective part on the transom assembly having something to do with the hose nipple (or related) going to the sea pump. My leak issue seems to be RPM or speed related and the only trace of water I've seen runs in at the transom plate. My bellows seem AOK upon inspection.
