-   -   Mefi conversion (https://www.offshoreonly.com/forums/do-yourself-boating-budget/342698-mefi-conversion.html)
1 2 NV 11-17-2016 02:52 AM
Mefi conversion
I've read just about everything on converting from differing Mefi units. I'm having issues with my engine and I'm almost to the point of converting. I have a Mefi 1 but have a spare 4b ecu laying around.
I'm not new to repinning wiring harnesses but I have found very little in detail of the conversion. I have both ecu pinout diagrams and they appear really similar. The biggest thing I know to be different is the Mefi 4 has a crank angle sensor vs the sensor in the distributor like the Mefi 1. But I believe the Mefi 4 also sends a signal from the distributor. Who should I call or contact for a 5 minute phone call to solve my questions?
TruxtonFox 11-17-2016 05:49 AM
Give me a few to get to my office and I'll send you the service manual. Should have everything you need as far as pin placement
1 2 NV 11-17-2016 09:24 AM
Thanks. I think I have everything. The main thing is do I need the CAS for the mefi 4 ecu to operate correctly.
articfriends 11-17-2016 04:34 PM
No, I have mefi 4's on several motors without crank angle sensor, Smitty
1 2 NV 11-21-2016 03:28 PM
Thanks. I thought for sure it would throw a code for no signal from the sensor. I thought it would need the CAS deleted from the programming.
sutphen 30 11-21-2016 07:46 PM
its all in how the ecu's program is configured.I've used the 4b on the 496's w/ crank and cam and also on my hei engines were it only has a 6 pin distributor.I could,if I wanted to set it up for dis set up and I believe it will work w/ 24,58 tooth crank trigger set ups.
tunertech 11-24-2016 11:02 AM
the complete 4 family support 7x 24x and 58x or 60-2
1 2 NV 11-24-2016 11:28 AM
I've been searching OSO for quite awhile now. Is there any advantages to a LT4 hot cam on a mefi 1 system? I've found a ton of info on cars/trucks and boats with carbs. Virtually nothing speakable on boat EFI.
No Coast 11-24-2016 01:21 PM
I've been following your other thread regarding your engine performance. The problems you are having have nothing to do with the series of MEFI computer
1 2 NV 11-24-2016 01:33 PM
Much appreciated. I've been milling around the jet boat forums and it seems that my engine is right on par with others. I believe my friends low hour 350 was a factory freak or his tach was off. It's fairly hard to find a 2.9 impeller used. That's my next step.
Don't forget my fuel burn is something fierce. So I'm still sorting through that issue.
