Page 4 of 4
Go to
-   -   502 Exhaust Manifolds and Risers time (https://www.offshoreonly.com/forums/do-yourself-boating-budget/342839-502-exhaust-manifolds-risers-time.html)
AllDodge 12-07-2016 11:57 AM
Quote:
Originally Posted by sergeantnic (Post 4507581)
I'll try some sandpaper but I'm fairly certain it is pitting from corrosion. Pictures just don't show it well.
Assuming it is not gasket material, same question as before. Will just the gasket suffice?
The gasket should be able to seal it
sergeantnic 12-11-2016 06:29 AM
So I got the port side all put back together. Hooked up the hose and ran the boat. I loosened up the hose clamps on the down pipe to verify I was seeing water and I can see water coming out the back of the boat.
The exhaust collector is pretty hot to touch but I'm fairly certain it has always been. Is there any way I can verify water is going through the cooling ports? The water I see in the exhaust could be from the bypass that connects directly to the elbow so just want to make sure I'm getting the right amount of water passing through there.
Is there a specific temp I should be trying to make sure the collector is running under? Engine temp never seemed to get high but I'm guessing the exhaust temp sensor just feeds to the computer and would throw an alarm if it got too hot.
I'll tackle the starboard side next weekend.
AllDodge 12-11-2016 07:38 AM
The exhaust should not get so hot that it will burn your skin when touched. One side will be cooler then the other, that is just how the water flows. I'm going to guess that since your not having trouble with overheating, you probably don't have an issue
Blueabyss 12-11-2016 02:17 PM
Put this on both sides of the gasket and its done. I also put it on the bolt threads . Sort acts like a mild thread locker and anti seize all in one.
https://www.walmart.com/ip/Permatex-...&wl13=&veh=sem
Chris
sergeantnic 12-25-2016 06:46 AM
Got the starboard side all back together and ran her yesterday but just around the canals at idle speed. I'm still worried about the temp. I can lay my hand on the starboard collector and it is cool to the touch. But I can't hold my hand on the port side for more than 1 or 2 seconds if that. It is very hot.
I know the port side is typically warmer than starboard and maybe this is just a matter of I'm only running at idle. Just want to see what you guys think.
AllDodge 12-25-2016 07:24 AM
I don't see an issue
2  3  4
Page 4 of 4
Go to
