502 "Canvas" - recommendations for reliable 550HP
19165956 Gen VI Merc EFI Long Blocks - low hours.
Removing stock EFI hardware and going Carb w Victor Jr intake Closed cooling (own) Gil exhausts (own) Adding oversized oil coolers (own) Heads look decent and very clean: Rev C 900-343944 stamped on them So what would you do with them to get to 550-600 reliable? CAM? Keep EFI CAMs or go 741? If change CAMs - what springs and head work? Carbs - which ones? Bump compression or leave it? What head gasket? Swap plug order? What electrics? Thanks Swamp |
| All times are GMT -5. The time now is 08:28 AM. |
