-   -   496HO to 454 swap (https://www.offshoreonly.com/forums/do-yourself-boating-budget/344549-496ho-454-swap.html)
MattBrewer1216 02-08-2017 11:12 PM
496HO to 454 swap
Hey I have a 2004 24' aftershock tremor with a stock 496HO with about 175 hours and a bravo 1. With a 24 prop and about 4900 rpms I can do 65ish. The boat and trailer weigh 6300LBS. Anyways like everybody, I want to go faster but looked into it, and anything for this motor is expensive. It looks like getting raylar products would be my only option that I've seen.
I was wondering if I bought an old 454 and built it up to say 600hp, would be cheaper than building my 496. I'm hoping one or some of you can give me advice. Is it going to be a waste of time and I should just build up the 496? Also if I'm easy out of the hole, would I be ok with 600hp or close to it and a bravo 1? I go to lake Mohave and lake Havasu all the time and I'll never be close to the fastest, but I hate losing to a seadoo. I want to be close to 75-80
class6 02-08-2017 11:24 PM
Whipple
MattBrewer1216 02-08-2017 11:26 PM
Put a whipple on which motor? Looks like it's going to cost a small fortune to forge my 496
class6 02-08-2017 11:49 PM
Put it on the 496. You won't hurt that motor. Stay at 5psi max and 5200rpms and you'll be good
VoodooRob 02-09-2017 05:37 AM
^^^^ and buy a back up drive, cheap enough to stay on the water
Dave M 02-09-2017 05:52 AM
I know this doesn't answer your question but I will offer this advice. If speed is your game, start with a fast hull. Unless you are in love with this boat, sell it as-is and buy a faster hull. Look for boats that are fast with stock power.
underpsi68 02-09-2017 07:13 AM
I love my 496 l, but I wouldn't put boost into it while using the stock pistons. IMO I would leave your boat alone and enjoy it.
IGetWet 02-09-2017 07:24 AM
Buying a faster boat is always the more cost effective way to go faster, but not always the most fun. If you get a block and build it up to 600hp with good parts and to be reliable will probably cost a lot more than what you think, good exhaust is 3000 to 6000 alone. If you ask me you'd be taking a step backwards technologically as well. Not saying your idea is terrible but sticking with the 496 may be a better option.
Here is a dimension link: https://www.perfprotech.com/blog/art...54-496-repower
As far as the bravo with that power, you'd have to be checking gears and lube often to stay ahead of the failure. =repeated spending money and time on it and taking it "easy" = Where's the fun in that?
These boats are spelt BOATT, bust out another ten thousand
class6 02-09-2017 07:26 AM
Just to add for reliability. We had a 2004 Chevy 3500 service truck weighing at 13000lbs and pulling equipment trailers from 10k to 15k. Reving 5k on hills. thought you were in a boat with fingers crossed and feeling bad for it. Well, it did it for 275000 miles when we sold it.. and its still going. another guy on here has it now. The 496 is not as weak as you think.
ezstriper 02-09-2017 07:30 AM
best bet would be a newer 502..500hp and go from there, the 496 complete has good resale $$
