-   -   EFI to carb swap, what all will be needed (https://www.offshoreonly.com/forums/do-yourself-boating-budget/344860-efi-carb-swap-what-all-will-needed.html)
rbrtbarker3 02-21-2017 06:30 AM
Changing the top end on my 1999 454 MPI mag to intake and carb. What all will I need to do this? My concerns are wiring harness, fuel pump, currently has the cool fuel system on it, and if current throttle cable will work. I have a thunderbolt IV ignition off another boat I plan on running. I'm sure there are things that I am not thinking of.
ezstriper 02-21-2017 07:58 AM
Its a easy swap, the EFI harness is stand alone, as far as merc dist is concerned not sure but a early one would work for sure, I usually run a H/P HEI on these and works well. you will have to set up a low pressure fuel pump as you only need 6-7psi, I used elec in the past as I dont care for the mechanical pump run from water pump.
BUP 02-21-2017 10:55 AM
Wrong questions on part - Sorry about that one, deleted them
Baja Rooster 02-21-2017 11:19 AM
The Holley Sniper efi kit is almost as easy as a carb swap. Might be something to consider.
