454 Closed cooling to 496 exhaust manifolds
I have a 87 454 mercruiser with closed cooling system I want to change over to the 496 exhaust manifolds and risers , but not sure exactly how to plumb the cooling hoses. Has anyone done this swap before I know its been done with the raw water cooling, I may be over thinking this but I just want to make sure I get it correct.. Thanks Jamie
Anyone ??
Ayuh,.... What BBC exhaust manifolds are you callin' 496 manifolds,..??
Your manifolds now are in the closed loop?
The water supply that cools the closed loop should just run out through the manifolds |
Bondo , they are the mercruiser 496 ho manifolds]
Need a picture of your current thermostat housing. It can be done.
Chris |
http://www.crowleymarine.com/parts/2...q=22-862210A01
This is what I used in the bottom of the 496 manifolds. https://www.wholesalemarine.com/ther...FQERaQodPwMLvw This is what my thermostat housing looks like. |
2 Attachment(s)
Originally Posted by jamie 10017
(Post 4535463)
[ATTACH=CONFIG]565449[/ATTACH] This is my guess of what you want to do. Would need different manifolds [ATTACH=CONFIG]565450[/ATTACH] |
You don't need to use both inlets on the bottom of the 496 manifold. Use the one that points forward and plug the bottom. or change the unit to a 90* fitting
Ayuh,... 'n Hopefully the H/E is big enough to include the manifolds,...
| All times are GMT -5. The time now is 11:50 AM. |
