-   -   Eddie Marine Flush Kit (https://www.offshoreonly.com/forums/do-yourself-boating-budget/345316-eddie-marine-flush-kit.html)
Tractionless 04-03-2017 09:30 AM
Originally Posted by kevinb230 (Post 4542468)
Just my opinion and I am as entitled as you are. Its known that heat and plastic aren't a lasting combination, versus metal. FURTHERMORE... I wouldn't trust my cooling capacity to some spring that can get jammed up with sand.
Remember, you're no bigger expert than I am and this is a discussion forum. So don't put others down with condescending remarks. Thanks
I see no condesending remark in my post but you're entitled to your opinion. By the way you're trusting your cooling capacity to "some spring" on your thermostat. :poopoo:
RidnMcNasty 04-12-2017 09:10 AM
I dont know whether or not the perko kit is better, not up to me to figure that out. I just didn't like the idea of plastic. I'm sure in 99.9% of the applications its used it would be perfectly fine, which probably included mine. But Murphy has a knack for following me around at times so I figured I'd eliminate that possibility.
