-   -   Big Block timing mark? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/346034-big-block-timing-mark.html)
oopee 04-07-2017 02:01 PM
Hi all,
I'm a bit new to big block engines and now I need to check and align the timing in my engine. Just wanted to make sure is this red marked piece supposed to indicate the TDC?? I just haven't seen this kind of structure structure before (..even in the pictures) so just wanted to make sure.
https://www.dropbox.com/s/j5ezg82wx3dttdj/bb.jpg?dl=0
F-2 Speedy 04-07-2017 02:21 PM
line up the end of the pointer and the long line that is tdc.........looks to be a gen 6 timing cover
oopee 04-07-2017 03:02 PM
Thanks!, yes according to the cast number the block is gen 6...
getrdunn 04-09-2017 06:13 PM
These are nice way to confirm TDC. Theres no guessing.
https://www.summitracing.com/parts/cca-4795/overview/
dcb 04-12-2017 02:04 PM
Some merc engines need to be put into "base timing mode" to set timing.
