-   -   Dissolving aluminum corrosion (https://www.offshoreonly.com/forums/do-yourself-boating-budget/347734-dissolving-aluminum-corrosion.html)
C_Spray 06-18-2017 10:19 AM
Has anyone had any real success in dissolving the corrosion that coats aluminum over time?
I've got an (anodized) aluminum piece that is stuck inside an aluminum casting, and have been soaking the parts in PB Blaster for weeks without success It seems that either a strong acid or a strong alkaline solution will do the trick, as long as everything is well-flushed afterwards. Suggestions range from diet soda to sodium hydroxide (Drano crystals) to muriatic acid. Any stellar success stories out there?
madbouyz 06-18-2017 10:28 AM
A pic of what you're dealing with might be more helpful to show exactly what's going on .
Is this a surface corrosion like what happens on an outdrive that's been scratched in salt water ?
If my memory serves me right though , don't go anywhere near anodized aluminum with muriatic acid .
AllDodge 06-18-2017 12:07 PM
Try the CLR
Navy has been dealing with this for many years, and paint seems to be the best solution after its cleaned up.
C_Spray 06-18-2017 01:11 PM
8 Attachment(s)
The anodized piece is about 1-1/4" in diameter, and fits into a raw aluminum bore in the transom shield. The seal is accomplished via an o-ring. I've already decided that the anodized piece is scrap, and have the replacement in hand. Here are some photos of the new anodized part, a freshly-assembled set and 2 shots of the corroded assembly with my pulling clamp attached.
dereknkathy 06-18-2017 02:27 PM
can you safely get some heat on that? outer not real thick. should heat up and expand quickly. do it while you have puller pressure on it. this is on inside of transom and you are pulling it in? any access to outside to lube and add persuasion bfh style?
C_Spray 06-18-2017 03:01 PM
I've tried heating it a couple of times, but both the shield and the offending part are aluminum, so there's not much differential expansion. (Plus, there is a 1/2" thick o-ring that seals the shield to the transom. I don't want to cook that.) No way to hit it from the inside, It's soaking in lemon juice right now, as citric acid is supposed to attack the aluminum oxide...
RSCHAP1 06-19-2017 09:58 AM
Muriatic acid does a good job of eating oxidation off aluminum.
VERY harsh, CAREFUL.
But it does clean up really well and my have a good chance of making down into the bore and loosening things up.
BUT...BE CAREFUL ! ! !
C_Spray 06-19-2017 08:51 PM
2 Attachment(s)
OK, I spent a couple hours with a syringe squirting muriatic acid around the anodized part. It definitely had an effect, bubbling away with smoke and chlorine fumes. In the end, it looks like there's a small gap between the parts, but they still haven't let go. I tried my puller again, with no luck, but I can get the part to move a tiny bit side-to-side if I whack it with a hammer. I flushed it out with water and then sprayed it down with CRC 5-56 to stop any corrosion until I can get to it again tomorrow...
TooLateVTEC 06-19-2017 09:08 PM
Now that you have some play in it, find some of the Loc Tite Freeze off spray in the aerosol can use that. That stuff can work wonders, the longer you spray it the colder it makes the part youre spraying it on.
If it doesnt work itself, add some heat to it and then use that spray and the temp change may get them to break loose.
SB 06-19-2017 09:20 PM
Have you tried turning it...sometimes that will break the sticktion. Have to do this all the time with wheel bearings hubs in aluminum sprindles. Airhammers/lomg bars/you name it...lol. Haven't found any chemicals to help yet.
Tractionless 06-20-2017 12:41 AM
I used an acidic solution on my trailer fenders;however, it only came back after 4 mos. or so, what an eyesore! I took them to get powdercoated 2 weeks ago for $200 total. Should have done it long ago.
Wally 06-20-2017 07:39 AM
cant you take the screws out of the block of aluminum and split the two pieces apart?
dereknkathy 06-20-2017 08:02 AM
I believe that block of aluminum is his puller.
madbouyz 06-20-2017 01:06 PM
Just for the record , like one of those consumer reports , I had a job last year to dismantle some high end outdoor furniture for re-finishing . The furniture was powder coated aluminum and the bolts were stainless . Of course thanks to this gawd awful salty environment the aluminum had seized the s/s bolts to their threads in the furniture and we tried that Freeze off shyte. A total waste of money . Once I realized that all I was going to do was snap the heads off of the bolts we took the stuff to a machine shop and they extracted all the bolts and broken studs like magic.
Wally 06-21-2017 08:10 AM
That would make more sense ;)
C_Spray 06-21-2017 12:05 PM
10 Attachment(s)
Seems like brute force is the single biggest tool in the box. I had tried twisting it with a 12" wrench several times with no luck. After I got it moving a little yesterday, I got a 24" wrench on the clamping block and slowly got it rotating back and for a few degrees. Went back to using the jacking bolts, and finally got it moving and out. It's interesting to note that the muriatic acid attacked the bare aluminum far more than it did the oxidation. (Now you know why aluminum oxide is used on sandpaper...)
I couldn't get the anodized tube to unwind from the stainless fitting, even though I had used an anti-corrosion compound when I put the parts together (9 years ago), so I resorted to using a slitting saw to split it in half. (Exit $300+.) Now it's all cleaned up, sanded and repainted where the acid stripped the paint on the transom shield. Once the paint has cured, I'll clean up the bore in the casting with sandpaper and scotchbrite, then assemble it all back together with copious amounts of waterproof lithium grease. (And dismantle and re-grease them at least once a season from now on...
C_Spray 06-21-2017 12:13 PM
2 Attachment(s)
By the way, here's the breakdown of what I've been working on. Parts 25 through 32...
RSCHAP1 06-21-2017 01:52 PM
WOW
That is some serious bonding between pieces
C_Spray 06-21-2017 07:40 PM
Yup. A nasty problem defeated by patience and persistence... ...and brute force.
phragle 06-21-2017 07:51 PM
If you look up what anodizing is, its an oxidation process that changes the surface composition. Its that oxidized layer that protects the aluminum and makes it tougher.
C_Spray 06-21-2017 09:38 PM
I've been around anodizing for decades. That's why I'm surprised that it wasn't effective in this application. Maybe seawater electrolysis defeats the anodizing. If I still had access to a lathe and mill, I would have whipped up a pair of these in 316L stainless!
Tractionless 06-24-2017 02:45 AM
Whenever i run into such issues adn eventually solve them I simply tell the wife, "I Win!"
dereknkathy 06-24-2017 05:52 AM
those hunk of zinc are called anodes for a reason...
