-   -   bplace to mount oil temp gauge sending unit? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/348093-bplace-mount-oil-temp-gauge-sending-unit.html)
iroc fan 06-30-2017 03:41 PM
Where would be the best including simple place to mount sending unit for the oil temp gauge on a 6.2 Mercruiser? Trying to keep it simple as in not drilling into pan or anything but in a spot that will read it ok.
iroc fan 06-30-2017 04:00 PM
Could I put a T where the oil pressure gauge is?
dereknkathy 06-30-2017 07:50 PM
better down in oil flow. once it is in pressure sender pipe, it is kind of stagnant and I don't think give you a good temp reading. here. https://www.google.com/search?q=350+...=1498870089640
Peterkvs 07-01-2017 06:55 AM
I mounted mine in the remote oil filter housing in the alternate input port.
iroc fan 07-01-2017 09:45 AM
That seems like a great idea, guess I will look into that.
iroc fan 07-01-2017 02:02 PM
Can't find any other ports on my remote oil filter adapter.
dereknkathy 07-01-2017 05:21 PM
Then put it in the block just above oil filter. See pic from post 3.
iroc fan 07-01-2017 07:21 PM
That is where my oil pressure sending unit is at. I thought there were other locations on the block where this could be added for some reason. Might wait till next oil change to add it and put it in drain plug hole in pan.
Powerquest230 07-01-2017 08:00 PM
Wouldn't you want it located near the hottest point with constant flow?
dereknkathy 07-01-2017 10:24 PM
Same picture up top behind intake manifold. That is oil pressure sensor. Relocate pressure sensor there and temp down low above filter.
