-   -   496 HO oil temperature sending unit (https://www.offshoreonly.com/forums/do-yourself-boating-budget/349307-496-ho-oil-temperature-sending-unit.html)
speedfever 08-21-2017 07:28 PM
Where is the oil temperature sending unit on a 2003 496 mag ho ?
BUP 08-22-2017 12:32 AM
the oil pressure sender for all marine 496's is located on the top backside of the engine but down a bit in a lowered flange ---- screwed into a 45 degree fitting and another fitting reducer screwed into the block flange. Hope that all makes sense.
Later 496's the fittings themselves changed. and location was almost in the same place.
Senders need to match the OHM's to the gauge for proper psi readings.
underpsi68 08-22-2017 05:37 AM
Are you looking for oil pressure or oil temperature? There is no oil temperature sensor on a 496.
BUP 08-23-2017 12:22 AM
I seen that to so I just posted about the oil pressure sender as I thought he was talking about. Anyways if not someone else will want to know down the road about the oil pressure sender.
stock 496's do not have oil temp readings
boatnt 08-23-2017 06:29 AM
my stock 496s have them,,maybe Fountain adds them to the engines,,not sure
techman 08-23-2017 07:06 AM
My 496 HO's have oil temp readings, both gauges and Smartcraft. So there are oil temp senders on the engine along with pressure sensors.
BUP 08-23-2017 01:07 PM
Not that my info comes from Raylar because I actually work on marine 496's across the board. Merc, Volvo, Indmar and so on since day one when they came about to market. . I tried to do a search on the this. " oil temp reading on a Merc 496" , basically this is what comes up. Link below to click on.
Read post number 3 in the link below.. Like I said STOCK apps do not come with oil temp senders or oil temp readings.
http://www.offshoreonly.com/forums/g...mp-gauges.html
SB 08-23-2017 01:55 PM
Probably a Fountain thing....they also put water psi gauges on a lot of their boats.
speedfever 08-23-2017 06:58 PM
Yes, it is a Fountain thing
BUP 08-24-2017 08:30 PM
I totally understand that but not every single one plus your info shows 1997 with 500 hp's inwhich is no 496 just saying.
