-   -   Gil manifold plumbing (https://www.offshoreonly.com/forums/do-yourself-boating-budget/350277-gil-manifold-plumbing.html)
F-2 Speedy 10-16-2017 02:31 PM
contact some of the parts sellers in swap shop, Im sure they have a couple, 115 bucks what a bargain..........:lolhit:
dereknkathy 10-16-2017 04:17 PM
2 pipe tees and 6 nipples. 10 bucks at lowes. Little black paint...
veloc410 10-16-2017 06:26 PM
Originally Posted by Griff (Post 4588074)
Factory Merc Racing with Gil's and the 4 outlet Tstat housing used a T at the top of the manifold just before the riser.
I have that thermostat housing . Make sure you monitor you engine temp. Not just the thermostat housing. I had overheat problems last year . Fresh water pressure was dead heading hot water exiting engine through manifolds. The temp gage was reading around 140 but when I added a sender to the water cross over on the intake it was well over 200 just idling. Warped valves. wasn't happy . They were New engines. I modified my housings so all hot water exits out the transom separate from incoming fresh. The exhaust manifolds were not factory. Now the manifolds and engines both run cooler.
veloc410 10-16-2017 06:39 PM
Sorry. I was referring to the pic grif posted
