Change oil before or after winter?
Charter Member #1171
while winterizing...... get the contaminates out of the engine
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Change it after your last run, don't let the contaminants sit in there all winter and settle into the pan. Oil changes are pretty simple and quick too. You can rest easy all winter then without any concerns.
Before layup and always with 5W20 Redline!
Change it in the fall,add fuel stabilizer, run it to to get the oil hot and to pump the new oil into the lifters, winterize, hook the battery to some sort of maintenance charger and walk away.
In the spring, drop it in the water and turn the key.
No need to change the oil again
You really should restart the engine, because if you don't, the only engine part that gets the benefit of the new slug of additive is the top of the oil pan.
Ken
Ken
